2002 Citroen Berlingo 1.6 16V Citroen berlingo underpowered
100,000 MILES • 4 CYL • FWD • MANUAL
FEHILLY3
My citroen berlingo wont rev above 45000 revs and is worse when under load. I chnged the air filter and Spark plugs(that were perfect tan brown colour) but have had no effect. The power output varies sometime higher sometimes lower. I need the car fixed due to the colossal amount of fuel is using. Any ideas?
Jan 9, 2010 at 7:45 PM
DAVE H
  • 13,383 POSTS
Hello . thanks for the donation .. much appreciated Have the vehicle plugged into a diagnostic computer to scan the cars computer for fault codes .. the codes will tell us in which system the fault lies .. repost with full codes for more assistance and repair information .. in the meantime add a good fuel addative to the fuel tank to clean the fuel system and injectors ..
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_952.png
Jan 10, 2010 at 8:47 PM
FEHILLY3
hi,
Have already cleaned the injectors and replaced fuel filter. I had fault code p0420 (catalyst below efficiency bank 1) Do you think this could be an issue with the cat or exhaust? Its causing the car to be drastically underpowered
Thanks
Jan 11, 2010 at 4:59 AM
