Cim in need of repair?
84,000 MILES • 4 CYL • 4WD
MRALVIN
I have a skid light on time for service light on my settings on the steering wheel does not work when I try to use the settings button there is no beep.
Nov 18, 2023 at 9:35 AM
  • 110,248 POSTS
I suspect you are referring to the column integration module. Is the airbag light on?
Keep in mind, there are several things related to the CIM. If you haven't already, check to see what diagnostic trouble codes are stored so we know what direction to go.
Here is a link that explains how to scan the can-bus:
Let me know what you find. If you already know specifically what needs to be done and need directions, let me know. Otherwise, let me know the code or codes retrieved and I should be able to determine what to do next.
Nov 19, 2023 at 12:09 PM
