over heating replaced thermostat
2006 CHRYSLER
124,000 MILES • 3.5L • V6 • RWD • AUTOMATIC
SHAUNPATTERSON
Car started to run hot I put a new thermostat on it, but it is still running hot.
Oct 29, 2016 at 8:23 AM
OBXAUTOMEDIC
  • 3,719 POSTS
Hello Shaun,
OK, Have you noticed whether the Fan come on or not? Also, if you have owned since new has the Radiator ever been replaced? Is the engine light on if so see about getting codes read.
One way to check the Radiator if not sure how old it is is to while it is cold run your finger carefully over the metal fins if they turn to dust replace it, it is not cooling properly.
If fan is not coming on check fuses it could also be the Coolant Temp Sensor hence an engine light being on.
Post vehicle model and submodel and I will get you Fuse Block Layout.
Mark
Oct 29, 2016 at 11:54 AM
OBXAUTOMEDIC
  • 3,719 POSTS
Just checking back to see if you have resolved you problem or not. We are here to help you get it fixed.
Thanks
Mark
Nov 3, 2016 at 8:39 AM
