CHT Sensor location please
170,000 MILES • 3.7L • V6 • 2WD • AUTOMATIC
JOOL79
Hello everyone! I need help finding the location of the CHT sensor on the car listed above. Thanks in advance.
Oct 11, 2020 at 12:53 PM
Good morning,
The sensor is on the back drivers side of the motor. It is not an easy replacement as it is very tight back there.
https://www.2carpros.com/articles/how-a-coolant-temperature-sensor-works
I attached a picture of the location for you to view. I also attached a connector for you to view. It has the color of the wires for the sensor. You will need a 3/4 or 7/8 socket or wrench to remove the sensor.
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
Oct 12, 2020 at 12:43 AM
