CHT-Cylinder Head Temperature Sensor location
120,000 MILES • 3.6L • V6 • 4WD • AUTOMATIC
DOC22
Where is the CHT sensor located on my vehicle listed above XLT?
Mar 26, 2019 at 11:48 PM
Good morning,
I attached a picture of the sensor location for you and the procedure for replacing it.
NOTE: If the cylinder head is being replaced, the CHT must be replaced.
1. Disconnect the Cylinder Head Temperature (CHT) sensor electrical connector.
2. Remove the CHT sensor.
- To install, tighten to 11 Nm (97 lb-in).
3. To install, reverse the removal procedure.
Mar 27, 2019 at 12:14 AM
DOC22
Awesome, thanks.
Mar 27, 2019 at 4:22 AM
