Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Lincoln
Navigator
Engine
Where is the CHT, cylinder temperature sensor located?
2015 LINCOLN NAVIGATOR
115,000 MILES • 3.5L • V6 • TURBO • 4WD • AUTOMATIC
BRIAN WILSON
MEMBER
1 POST
Need to locate cylinder temperature sensor.
Jun 21, 2022 at 12:46 PM
SQM
Experienced Mechanic
In order to access the CHT you will have to first remove the right-hand inner fender liner. This will allow you to get to the sensor.
I have attached diagrams below showing the location.
Let me know of any questions.
https://www.2carpros.com/articles/symptoms-of-a-bad-coolant-temperature-sensor
Images (Click to enlarge)
Jun 21, 2022 at 1:09 PM
Add image or video
Ask a new question
Engine won't start
Air Conditioner — Not Working
