transmission code
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Obtain the transmission-control fault codes with equipment capable of reading that system, and record the exact codes and symptoms before deciding on a repair.
Guidance references and applicability
Source: Original question and visible replies. Owner reports and other participants' experiences are distinguished. Next steps are editorial guidance for obtaining diagnosis or clarifying the reported findings; they are not a verified repair procedure or an independently confirmed component diagnosis.
Discussion summary
transmission code
The owner of a 2001 Dodge Caravan asked about P0700 after the check-engine light came on. The question described it as a request from the transmission control system to illuminate the malfunction indicator.
Reported outcome: No transmission-specific codes, component diagnosis or repair outcome were reported.
The reply called for a more specific scan. This discussion does not identify a failed transmission component or establish that a rebuild is needed.
