2001 Chrysler Town & Country Coolant Leak
DONOSB
I HAVE A 2001 CHRYSTLER T&C VAN 167,000 MILES 3.0L
. MY WIFE NOTICED LAST NIGHT THAT THERE WAS WATER COMING FROM UNDER THE HOOD AND THAT IT WAS ANTI-FREEZE. TODAY I RAN IT UNTIL IT WAS HOT ENOUGH TO GET THE WATER GOING AND THEN TOOK THE CAP OFF. ( DON'T WORRY THE CAP/ WATER WAS NOT HOT YET)
THE WATER HAD STARTED COMING OUT FROM UNDER THE CAP AND STARTED TO OVERFLOW. WHAT COULD BE CAUSING THIS? THE CAP WAS TIGHT WHEN I TOOK IT OFF. SO I DON'T THINK IT IS THE CAP.
Jan 30, 2007 at 6:25 AM
FFAS23
  • 25 POSTS
[quote:2dc2113efe="DONOSB"]I HAVE A 2001 CHRYSTLER T&C VAN 167,000 MILES 3.0L
THE WATER HAD STARTED COMING OUT FROM UNDER THE CAP AND STARTED TO OVERFLOW. WHAT COULD BE CAUSING THIS? THE CAP WAS TIGHT WHEN I TOOK IT OFF. SO I DON'T THINK IT IS THE CAP.[/quote:2dc2113efe]
They sell a tool to check a radiator for leaks. This tool screws onto where the Radiator Cap comes off. With the tool air is pumped into the radiator building up pressure to what ever pound radiator cap is on the car. If a 15 lb radiator cap, pressure is pumped up to 15lbs. At this point you should be able to see where the leak is coming from. Chances are you have a bad waterpump if the leak is coming from underneath it. There is a weep hole there and when water pumps start to go bad they usually start leaking there. You could also have a leak coming from the radiator. This tool I spoke about would also show that. Leaks can also be coming from the engine block such as at a freeze plug or even a loose or bad hose. If it is a little leak at the radiator you could go out and get some radiator stop leak for a temporary repair depending on how large the leak is until you can find the time to replace your radiator or have it replaced. If it is the water pump the stop leak product will not work for you. Hope I answered all your questions here. Antifreeze coming out of the area where the cap is installed with the cap off while the car is running and hot is a natural thing. The pressure has to push it out somewhere. You need to keep the cap on the radiator. With the cap tight nothing should be coming out of the radiator cap. If it is you may have a bad cap. If it is coming out of the overflow hose you could have a bad thermostat making the car overheat. Without seeing the car myself it is hard to pinpoint your problem here. Can only give you some ideas and things to look for.
Fred
Jan 31, 2007 at 10:09 AM
  • 75,988 POSTS
Pressure test the Cap-won't hold it-replace it. if it does now pressure test the Rad for leaks, No leaks -inspect the thermostat thoroughly-still no leaks can be caused by internal headgasket leak-Again pressurize the Rad to its spec's start the car up, if the needle is fluctuating erractically-you got yourself a blown gasket. Also a gas analyzer will read Hydrocarbons if its blown.also you can do a compression check on each cylinder-any low readings on side by side cylinder-blown gasket again
Do all the basics on the cooling system before you get to the headgasket
Jan 31, 2007 at 9:46 PM
Suggested Repair
Pressure-test the radiator cap and replace it if it will not hold pressure. If the cap holds, pressure-test the cooling system to locate external leaks at the radiator, water pump weep hole, hoses, or freeze plugs. Inspect the thermostat if coolant is pushed into the overflow. Only after those checks consider a head-gasket test using system pressure behavior, a hydrocarbon check, or a compression test. Stop-leak is only a temporary option for a small radiator leak, not a water pump leak.
Conversation Summary
The owner of a 2001 Chrysler Town & Country with a 3.0L engine reported antifreeze under the hood. After warming the engine, coolant overflowed when the radiator cap was removed, though the cap had been tight. One reply explained that overflow with the cap off on a hot engine can be normal and recommended a cooling-system pressure test to find leaks at the radiator, water pump weep hole, hoses, or freeze plugs. A bad cap or thermostat was also suggested if coolant escapes with the cap installed or through the overflow. Another reply advised testing the cap first, then the radiator and thermostat, and checking for a head gasket only after the basic cooling-system tests.
