2000 Dodge Caravan Cold Engine Chatter
LEEOHM5
[color=red:4a6167e0fb][/color:4a6167e0fb] i have a 2000 dodge caravan with a 3.0 motor that makes a chattering noise in the mornning sounds like colasped lifters but goes away when the engine warms up for a while helpit has 70.000 miles runs good
Jan 25, 2006 at 3:10 AM
SC1 RACING
  • 117 POSTS
sounds like is taking awhile to get the oil to the top of the engine. has the oil been changed on recomended time/miles? if not or if you use a cheap oil it more than likely partially clooged from oil deposits. you can try to flush the engine but you must be careful, and they recomend you pull the oil pan and remove deposits with engines with high miles.
on older engines i like to use an additive for the oil. i prefer lucas, and have had good luck with it. if you do buy additive for the oil make sure it does not contain teflon.
Jan 25, 2006 at 3:19 AM
Suggested Repair
Check whether oil changes have been done on schedule and avoid cheap oil. The morning chatter is likely delayed oil flow to the top of the engine from partial clogging by deposits. Carefully flush the engine if appropriate, or pull the oil pan and remove deposits; an oil additive such as Lucas (without Teflon) may also help on an older engine.
Conversation Summary
Owner of a 2000 Dodge Caravan with a 3.0 engine and about 70,000 miles reports a morning chattering noise that sounds like collapsed lifters and goes away after the engine warms up; the vehicle otherwise runs well. The expert attributes the noise to slow oil delivery to the top of the engine, possibly from deposits if oil changes were neglected or cheap oil was used, and suggests a careful flush, oil-pan cleaning of deposits, and a non-Teflon oil additive such as Lucas.
