2004 Chrysler Van crank's but won't start
2004 CHRYSLER VAN
46,000 MILES • 6 CYL • FWD • AUTOMATIC
PLEH1965
I drove the van 20 miles and parked it and came out 15 minutes later and it cranks but won't start ?
Feb 18, 2009 at 4:55 AM
Get a starting fluid/ether/better off gas in a spray bottle and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Feb 18, 2009 at 5:08 AM
