2003 Chrysler Van running rough
80,000 MILES • 4 CYL • 2WD • AUTOMATIC
STEPH121755
Hi I have a 2003 Chrysler Voyage with about 80,000 miles and just in the past few months every time I turn on the AC and try to go it is like it has no speed at all and it takes a minute to get up to speed but once I am going it is fine. My check engine light is also on and I took it in to have it looked at and I guess they thought it was no big deal cause they cleared it but it has since come back on. Also when I am starting and the van is dragging like it is the check engine light will flash and then go back to solid once the van gets going. It only does this when I run with the AC on, when not using it, it runs fine. Not using the AC is not an choice until it cools down some. Any help I can get would be wonderful.
Jul 23, 2008 at 2:57 AM
DOCFIXIT
  • 18,828 POSTS
When the light is on go to anAuto Zone they will code free. Then post results.
Jul 23, 2008 at 3:19 AM
