2003 Chrysler Van jerks when braking around 50 kilometers
190,000 MILES • 6 CYL • AWD • AUTOMATIC
MANGOSTEEN
when braking it jerks around 50 kilometers,and it always happens. could it be some sort of a solonoid console attatch to the outside of the transmission that needs to be changed.thank you.
Feb 15, 2009 at 2:40 AM
  • 110,244 POSTS
Hi:
IF the problem only happens when you are braking, I would say it is brake related. Can you describe what happens? Does the car pull to one side? Is there a pulsation? have you checked to see if a wheel cylender is leaking?
Mar 20, 2009 at 6:26 AM
