2002 Chrysler Van water pump pulley removal
2002 CHRYSLER VAN
FYREWOLF
Engine Cooling problem
2002 Chrysler Van 6 cyl Two Wheel Drive Automatic
I'm having a problem getting the water pump pulley off of the water pump housing, how can I get it off so I can replace the water pump? Its on the right side of my chrysler voyager near the wheel well and i can't remove the pulley to access the pump, is there a trick to remove the pulley
Dec 2, 2008 at 11:24 PM
  • 110,244 POSTS
Hi:
There isn't a trick to removing it. Are you working through the inner fender to access the pump? It will make things easier. Once you remove the pulley bolts, it should come off.
Dec 3, 2008 at 2:54 PM
LOOSENUT47YAHOO.COM
I have a 2000 voyager, and in the process of replacing the timing cover, and pulled one from the salvage yard. pulling the one from the yard, i used a rubber strap wrench to hold the pulley while i loosened the bolts, and removing the old pump off my van i used a screwdriver to wedge in one of the holes on the pulley to loosen the bolts.
Dec 30, 2008 at 6:36 AM
