2002 Chrysler Van Oil light coming on during braking and id
79,500 MILES • 4 CYL • 2WD • AUTOMATIC
JOECLARKE02
I just picked up my 02 Voyager. It was in to have the cracked oil pain replaced. Since getting it back, the oil light has been coming on when braking and at idle. The oil level is fine. It was not doing this before it went in to the mechanic. Please help, thanks.
Sep 13, 2008 at 8:25 AM
  • 110,248 POSTS
Hi:
The cheapet and easiest thing to try is to replace the oil sending unit. It may be going bad. Also, ask the mechanic if the pick-up tube was clean when he replaced the pan. If there is anything blocking the screne, it could cause this problem. Finally, when the light comes on, does the engine make any sounds like a knock, tap, or ping? If not, most likely the sending unit.
Nov 8, 2008 at 10:01 AM
