2002 Chrysler Van Heater Problems
TEGA0311
Heater problem
2002 Chrysler Van Front Wheel Drive Automatic 115000 miles
My girlfriends van does not blow out hot air. The air conditionaer works. But the weather is getting cooler out. She can not use the defrost to defrost the windows. She is not able to use the hot air from the engine to warm the van. It feels as if the just the fan is on. Also the speed control works only in the high position. For the AC and the fan. What do you think could be wrong?
Oct 4, 2010 at 11:43 PM
  • 75,988 POSTS
Try replacing the thermostat and also check the blower motor resistor
Oct 5, 2010 at 2:58 AM
