2002 Chrysler Van BRAKE LIGHTS
99,100 MILES • 4 CYL • FWD • AUTOMATIC
DELUXDAIRY
My Brake lights do not work, all other lights do. Replaced the fuse and the switch and they still do not work. I do have the towing option, however I have never towed with this van. I washed the van the other day, used a brush in that area to clean fly dirt - not sure if this is releated, but fuses are replaced and then blow out when pedal is pushed.
My repairman said he thinks it is something between the brakes and the back of the van - wiring - short etc
Aug 25, 2008 at 9:11 AM
  • 31,937 POSTS
Hi there,
you do have a short in the system, you will have to start to isolate sections of the brake light circuit and test, if this is beyond you, your mechanic should be able to do this job.
mark (mhpautos)
Aug 25, 2008 at 6:52 PM
