2002 Chrysler Town & Country P0740
KMILLER1
I have a Chrysler T&C Van with 106,000 miles on it. The check engine light came on and in checking the fault codes, displayed P740, which has something to do with the torque converter. The vehicle is still running/driving fine, but sometimes will downshift a little hard when coming to a stop. I reset the fault codes and took the vehicle out for a test drive. Everything was fine at city street speeds, however the check engine light came on again at highway speed of about 65MPH. Fault code was again P740. Vehicle is still running fine with the occasional hard downshift when coming to a stop. I contacted the local Chrysler dealer and all they would tell me is that the transmission probably needs to be replaced. Any suggestions or recommendations short of replacing the trans will be helpful. Thanks.
May 19, 2007 at 6:36 AM
  • 75,988 POSTS
[quote:3ae8e1fd8e="kmiller1"]I have a Chrysler T&C Van with 106,000 miles on it. The check engine light came on and in checking the fault codes, displayed P740, which has something to do with the torque converter. The vehicle is still running/driving fine, but sometimes will downshift a little hard when coming to a stop. I reset the fault codes and took the vehicle out for a test drive. Everything was fine at city street speeds, however the check engine light came on again at highway speed of about 65MPH. Fault code was again P740. Vehicle is still running fine with the occasional hard downshift when coming to a stop. I contacted the local Chrysler dealer and all they would tell me is that the transmission probably needs to be replaced. Any suggestions or recommendations short of replacing the trans will be helpful. Thanks.[/quote:3ae8e1fd8e]
Try disconnecting the TCC solenoid and retest.
May 19, 2007 at 7:15 PM
Suggested Repair
Disconnect the torque converter clutch (TCC) solenoid and retest to see whether code P0740 returns before considering transmission replacement.
Conversation Summary
The owner of a 2002 Chrysler Town & Country with 106,000 miles reports code P740, related to the torque converter. The van still drives, with occasional hard downshifts when stopping, and the code returns at about 65 mph. The dealer suggested replacing the transmission. The expert recommends disconnecting the TCC solenoid and retesting.
