I have a 2000 Dodge Caravan, I just bought cheap. drove it home with a knock. Pulled Transaxle out to examine flywheel for a possible crack. No Crack!!!
I have now moved on to the engine. I have droped the oil pan and discovered a couple of connecting rods that connect to the camshaft. I also noticed no oil in the oil filter.
I need advice: rebuild, Repair bearings or overhaul.
Which do you think would be my best alternative?
Nov 5, 2008 at 6:45 AM
