2000 Chrysler Van
123,200 MILES • 6 CYL • 2WD • AUTOMATIC
KESSLER5233
I have a 2000 chrysler voyager that when you drive it will not shift into 3rd.
When i had a computer put on it, I found out that the shift soleniod was bad now do i have to take the transmission out or is it on the outside
Jan 24, 2010 at 9:24 AM
CARADIODOC
  • 34,414 POSTS
The solenoid pack is bolted to the front of the transmission. It sits under a foam rubber noise-cancelling cover.
caradiodoc
Jan 25, 2010 at 10:55 PM
KESSLER5233
THANK YOU SO MUCH FOR THE QUICK RESPONSE TO MY QUESTION. IT TOOK ME AWHILE TO GET THE PART ON BUT IT WAS WORTH IT. YOU SAVED ME AROUND $2500. ONCE AGAIN THANK YOU.
Jan 30, 2010 at 5:35 AM
