1996 Chrysler Van Wont start
121,357 MILES • 6 CYL • 2WD • AUTOMATIC
LH5090
My wife just put gas in the van. Went down the road. It backfired, died and now it wont start.
Nov 12, 2008 at 6:40 AM
  • 75,988 POSTS
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Nov 12, 2008 at 7:30 AM
