MALIBUMAN81
My 2000 Chrysler T&C van 115K mile 3,3 L has developed a strange noise.
It is only audible when the van is cold or basically sits all night. when started it sounds like a groaning, when the motor is reved slightly it seems to disappear but when the rpm's are lowered again it's back. It also seems louder when you put it in gear. Once the vehicle is warmed you never hear it. I used the old tire iron to the ear trick and am confident its NOT the transmission, water pump or altenator, it really sounds like its coming from the intake manifold?? What could this be??
Thanks for any help on this
Don
Nov 13, 2007 at 11:05 AM
2CARPRO JACK
  • 11,533 POSTS
Fords do that kind of thing when the Idle Air Control Valve goes out, but I havent seen a Chrysler do it.Try removing it and cleaning it out with carb spray.
Nov 14, 2007 at 12:00 AM
MALIBUMAN81
Thanks for the reply Jack, Ill give it a try
Don
Nov 14, 2007 at 8:39 AM
