check engine light bulb is off
SELFIXER
Chrysler Town & Country 2001 model 3.8 Liter V6 with 119000 miles on it. I brought the van to the emmision center and it failed the MIL test because there is no light coming from the check engine light bulb even when the switch is on and before starting the engine. The bulb maybe burnt and needs replacement. Is it really sure that the problem is the bulb?
Oct 28, 2007 at 12:09 AM
DAVIDR70
[quote:78a62deae1="justanold"]HELLO! Thank You for the donation! What you describe is a bad vacuum line connection or a leaking motor. i'm pretty sure that the line is disconnected at the motor. located on the far pass. side above the blower motor. as i recall your access is through the glove box opening. let me know if you have any ??s and how you fare. 8) 8) 8)[/quote:78a62deae1] would the line your speaking of be the one hooked to the bottom of the motor that air blows into? if not do i have to take the glove box out to see this line? Thanks for your reply Randy
Aug 15, 2007 at 1:43 PM
