2008 Chrysler Town and Country horn
30,000 MILES • 6 CYL • FWD • AUTOMATIC
RTCLARC
The horn on my 2008 T&C blows on its own. I have not been in the car when it happens but it is usually a very short beep as if someone tapped the horn button quickly. I am told that it blew for about 20 seconds once but I was not present at the time.
I have raised the hood and jiggled wires and found nothing loose. I have also "exercised" the horn button on the steering wheel thinking it may be corrosion. Unfortunately the problem still occurs about once a day. Does anyone have a suggestion of what I can check?
Mar 25, 2009 at 6:46 AM
CARADIODOC
  • 34,413 POSTS
You bought a vehicle with a lot of unnecessary, complicated, unreliable, and expensive computers. Expect a comparable repair bill. This is partly why no one wants to buy new cars. It really frustrates me, and it's why I still drive a 1988 Grand Caravan. It uses a ten-dollar relay that rarely gives a problem. Be thankful you don't have a Ford. Two computers involved in blowing the horn! Typical cost of their inoperative horn is around $800.00.
As for your horn, it is likely being turned on by the Body computer or the Remote Keyless Entry computer. Is it possible someone nearby is using a key fob set to the same frequency as yours? If so, this problem would likely occur in the same place, such as work or home, not on a shopping trip.
Under normal conditions, your tail lights probably flash when the alarm sounds? If they do not flash when this intermittent problem occurs, I'd suspect a body computer problem. If they do flash when the horn honks unexpectedly, I'd troubleshoot a security system issue. Is there a possibility this is still under warranty? If it is, as long as the problem is documented as occurring in the warranty period, they will usually still take care of it if it's out of warranty when they finally find the cause.
caradiodoc
Mar 29, 2009 at 4:30 PM
