2007 Chrysler Town and Country turn signals
2007 CHRYSLER TOWN AND COUNTRY
23,000 MILES • 6 CYL • FWD • AUTOMATIC
CANDYMAN
Hello!
On my 2007 chrysler town and country van, the right and left turn signals will not turn off after making a right or left turn. You have to turn them off manually. What can I do to fix this? Thank You!
Jun 8, 2009 at 6:22 AM
LEGITIMATE007
  • 5,121 POSTS
the entire signal lever has to be replaced . in order to get it working correctly, there is a little switch in there that will snap it back when the steering wheel turns back strait and it has come loose. also, if the front end alignment is off center, it will cause the steering wheel to be off center , thus not allowing the lever switch to meet the steering wheel when it needs to so it wont shut off in that case either
Jun 22, 2009 at 5:29 PM
