How do I reset the ABS light after the replacement of a bad ABS sensor?
Jul 19, 2010 at 10:28 AM
✓Experienced Mechanic
It should reset itself. If it doesn't have the computer rescanned to make sure there isn't a different code and then have it reset with the scanner. If the same code comes back on, recheck your work and make sure there is no damage to the wiring.
Mar 17, 2021 at 12:24 PM
