2007 Chrysler Town and Country ABS light on but no codes
2007 CHRYSLER TOWN AND COUNTRY
57,963 MILES • 6 CYL • 2WD • AUTOMATIC
TCNTN
The ABS light is on but the OBDII reader shows no codes. Cleared code and light went off but came back on after 1 min of driving. There is a code for low voltage but battery showing 12.6 volts when tested. ABS connectors at front wheels look ok.
Jul 29, 2010 at 2:02 AM
  • 110,244 POSTS
Have you checked the wiring on the ABS sensors? Many times they corrode, come loose, or get damaged.
Jul 29, 2010 at 6:57 AM
