2006 Chrysler Town and Country tires
54,000 MILES • 6 CYL • FWD • AUTOMATIC
CLASSYLADY
i changed tires and the low tire pressure light came on and i will not go out what is wrong?
Nov 21, 2008 at 10:32 AM
BBBREV
The pressure sensors in the valve stem. The tire shop should have known. I have the same problem. If you had the work done recently make them fix the problem. If not, it's a pricey fix.
Aug 20, 2009 at 1:04 PM
