Replace serpentine belt?
2006 CHRYSLER TOWN AND COUNTRY
DDESERRE
i cant get the tensioner to loosen up how do i do that
Jan 30, 2010 at 3:12 PM
BMRFIXIT
  • 19,053 POSTS
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_649.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic2_306.jpg
Raise the vehicle on hoist remove tire and belt shield if still not able to get it to move tensioner is frozen and need to be replaced
Feb 1, 2010 at 12:30 PM
DDESERRE
i have a different tensioner there isnt a spot for that cant upload pic
Feb 1, 2010 at 2:02 PM
BMRFIXIT
  • 19,053 POSTS
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_650.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic2_307.jpg
Feb 2, 2010 at 10:14 AM
JAMBUCH
  • 5 POSTS
2004 Chrysler Town and Country 3.8 L V6.
The belt flaps between the air conditioner compressor and the crank pulley. It makes no difference if the AC compressor is enguaged or not.
It seems to be a function of the idle speed of the engine It flaps at 750 rpm =/- 150. At 600 or 900 it will not flap.
I have replaced the water pump, the alternator, serpentine belt last fall. The problem seemed to be fixed until now.
We have had a cool temperatures for the last few days and the belt flap is almost not existent. I noticed that during the cool weather that the idle RPM is at 600. As the temperature increase to the mid 90's the engine idles at 750 and the belt flap is back.
I have tried a second belt and a replacement belt tightner and found that the flap was more severe with the new Gates tightner.
The flap is independent of whether or not the air conditioner compressor is engaged.
All of the pulley are in-line and no visible wobble even when the belt is flapping.
My parts dealer indicates that he sells quite a few harmonic balancer drive pulleys. Could I have a deteriation of the rummer which is molded into the pulley?
Thanks for your help.
Jim
Oct 18, 2020 at 5:13 AM (Merged)
  • 110,240 POSTS
Jim:
I doubt the harmonic balancer is the problem. Are you certain that the belt is properly routed?
JAMBUCH
  • 5 POSTS
Yes the belt in on correctly. I had the flap problem last August and at that time I replaced the water pump, altenator and belt and the problem went away till Feburary of this year. I was on my way to Florida. It flaped for a day or so and then went away.
It returned late June this year. Replaced the belt still flaped. Replaced the tightner and it still flaped. With the transmision in park the belt doesn't flap. You turn on the AC on or off and no flap. Put the transmission in drive and the belt begins to flap. While in drive the belt will STOP flapping when the engine RPM slows down to about 600. Increase the RPM and the belt will flap between 650 to 850 RPM. 750 being the point where flap is the worse. With some one else holding the brake down I can observe about 1/2 inch of flap between the harmonic balancer pully and the A/C pulley. All of the pullies are running true. The belt tightner pully is moving to take up the belt slack.
With the belt off I have checked the all of the pullies for roughness and bearing problems by turning them. Nothing evident.
I got up yesterday and thougnt I would make a table of what I observed to help the mechanic figure out what to replace next. Started it up and backed it out of the garague. NO flap. Drove it around town and NO flap.
I tried the broom handle trick to listen to the altenator. NO bearing noise. NO AC bearing noise.
The only thing I can say definitly is it will only flap when the transmission is in drive and I stop at a stop light. People start looking around to see where the nose is comming from.
Could this be a transmission problem?
Expensive to have it repaired and it isnt the problem!
Same for the AC
This may be a good problem to stump your mechanic friends with.
  • 110,240 POSTS
The only thing I can say is the belt tensionier or a belt that is slightly too long. I don't think the trans has anything to do with it.
JAMBUCH
  • 5 POSTS
In my last note I indicated that the problem went away. That was on the 9th. It's back!!! on the 21st. I went on a trip and drove about 600 miles and it is back. It returned on the last day. Probably some where around 500 miles into the trip.
To day I purchased some fule injector cleaner to see if I have a miss at idle when the transmission puts load on the engine. Can't hear a miss.
JIM
  • 110,240 POSTS
Is it doing it all the time again?
JAMBUCH
  • 5 POSTS
It only happens when the transmission is in drive or reverse and the car is not moving.
Put it in neutral an the flapping stops. It makes no difference if the AC in on or off.
Jim
  • 110,240 POSTS
How low is the engine idling when in gear? Could it be caused by a very low idle?
JAMBUCH
  • 5 POSTS
I sure wished it had a carborator with an idle adjustment screw.
In neutral, with ac off, idle is 800 NO flap
In neutral, A/C on, idle is 725, NO flap
In drive, A/C on or off idle is 650, belt Flap
In reverse, A/C on or off, Idle is 650, Belt Fap
Put foot on brake and bring RPM up to 900 and flap goes away.
Last week when it stoped flapping for several days the idle RPM was slightly lower then 600.
Jim
Jim
KEL2SYD
when my van is idling it makes a tweetying like sound it is driving me crazy. we have replaced the serp belt, water pump and power steering. sometimes I believe it has something to with the air conditioner it is louder when it is on.
Oct 18, 2020 at 5:14 AM (Merged)
  • 110,240 POSTS
Hi:
It sounds like the belt is making the noise. A really easy to check it is to:
start the van
open the hood
with the engine running and tweeting, pour a small amount of water on the belts. Be prepared because it will splash water toward you.
if the sound stops, the belts are dry or the automatic tensionier is weak. keep in mind that the sound will come back when the water dries.
HOOSIERGIRL1960
I was driving in heavy rain last night. I was almost home when my battery and water light came on. As I was turning into my drive, my power steering went out.
This morning, the warning lights are off but I still don't have power steering.
About 2 years ago I had to replace the serpentine (sp?) belt after similar warning lights came on. Could it be the same problem? What else do you think it could be?
Thank you for your help!
  • 110,240 POSTS
If the belt got wet enough, it may be slipping. There should be a plastic cover under the engine covering the belt area. If it's damaged or missing, this will always happen.
LINBEN
2000 Chrysler Town and Country
price to change serpentine belt
  • 110,240 POSTS
The cost is usually around 60.00. You can get the belt yourself for around 15.00 and replace it. It isn't a big job. We have the belt routing diagrams if you get confused.
MCFLEMING
3.8L V6
Had replaced the casting that is the lower alternator mounting pivot point. Installed a new HD serpentine belt. All alignment seemed good. The tension indicator was at its mark. All functioned well for 3-5 months then the belt removed itself. Checked things and reinstalled the belt. 2-3 weeks later it repeated the removal. Reinstalled it and drove it home. Any suggestions?
RACEFAN966
  • 5,029 POSTS
I do have a suggestion. There is actually a bulletin on this and it is mostly for the belt jumping off when hitting a puddle of water or when the belt gets wet but it is the dual groove belt conversion kit. It is Napa number 38379K here is a pic. What it does is gives the belt gooves on both side there is no flat side to the belt.
https://images.2carpros.com/forum/automotive_pictures/249564_668397_1.jpg
MCFLEMING
racefan966
Thank you for the response! It is a vehicle we purchased for our daughter and both times the belt has come off its has been wet/rainy.
Are you a race fan and or a participant ?
Thanks again
RACEFAN966
  • 5,029 POSTS
Ok then I would look into the double sided belts kit and that will fix you problems. As for race fan it is both. I watch and race when ever I can. I race both circle and drag when I am able too. I perticipate at the local racing school here is a pic in one of the cars.
https://images.2carpros.com/forum/automotive_pictures/249564_007_2.jpg
HAHNY1
  • 75 POSTS
is it possible that the plastic shield underneath the vehicle is missing .
JOEL LEE
I need some direction on removing belt and water pump from my van.
ZACKMAN
  • 4,202 POSTS
It is very advisable that you invest $20 for a Chilton or Haynes manual for a complete instructions and photos. Our TSB is meant for technicians and only has the following plus torque spec.
https://images.2carpros.com/forum/automotive_pictures/55316_98tcwp_1.jpg
DEVILDOG232
I just recently changed the pump on mine it is a 97 also it is simple. Just put a breaker bar on the tension pulley on the nut and pull towards the front of the van and should release the tension on the tension pulley and the belt can be removed then it is simple for the water pump take of the impeller outer casing and replace it with the new one.
