2006 Chrysler Town and Country heater dlower will not work
40,000 MILES • 6 CYL • FWD • AUTOMATIC
DUNBARER
This is the 2nd time this has happened to me but the last time it worked the next day. While driving home in a blizzard I had to blast through some drifts and the blower stopped working so I had to drive home with the window open. Is this just an easy let it sit in the sun and melt or take it to a car wash to warm it up or is it more serious?
Feb 27, 2009 at 6:10 AM
  • 110,248 POSTS
H:
Does the problem seem to solve itself when it warms up? If so, when it happens, you need to see if there is power going to the motor. If there is, it sounds like the motor may be going bad or there is a ground problem. Check for broken or disconnected ground straps under the van. When you are at the motor, make a ground wire that you can reach a known good ground to see if the motor will work.
Let me know what you find.
joe
Mar 5, 2009 at 11:31 AM
