2006 Chrysler Town and Country Cannot Take the Water Pump Off
2006 CHRYSLER TOWN AND COUNTRY
40,000 MILES • 6 CYL • 2WD • AUTOMATIC
KAMRANA
I removed all the drive belt, removed the pulley bolts, and removed the pump mounting bolts. However, there just seems not enough space in front of the pump to be able to pull it out completely. I tried tilting to every angle. Have spent hours on it. Just can't pull it out. How can this be? Is there a trick to pull it out?
Thanks,
Kamran
Mar 8, 2009 at 3:07 AM
RACEFAN966
  • 5,029 POSTS
According to the procedure the pulley must be off in order to remove the pump. Here is a pic.
https://images.2carpros.com/forum/automotive_pictures/249564_Graphic_4.png
Mar 8, 2009 at 4:00 AM
SUPERTECT
  • 6 POSTS
FIRST OF ALL, YOU CANT TAKE THE PULLEY TOTALY OFF EVEN WITH THE BOLTS OUT. YOU WILL NEED A BIG SOLID PRY BAR AND GO BY THE SAME SIDE OF THE WATER PUMP IS ON AND MOVE THE ENGINE OVER TOWARDS THE DRIVERS SIDE, IT WILL MOVE ENOUGH TO GET THE PULLEY OF .IF YOU DO IT RIGHT, IV DONE LOTS OF THESE AT THE DEALERSHIP,THATS WHAT WE WHERE TOLD AT THE CHRYSLER SCHOOL, IT DOES WORK WELL , LET ME KNOW. THANKS HAVE A GOOD DAY!!!!!!!!!!!!!
Mar 20, 2009 at 2:40 PM
