2005 Chrysler Town and Country speedometer not able to read
2005 CHRYSLER TOWN AND COUNTRY
MISS33
Computer problem
2005 Chrysler Town and Country Two Wheel Drive Automatic
Speedometer hand spun around and is under the stop pin Do I need a whole new cluster to repair?
Oct 4, 2008 at 7:48 AM
  • 110,244 POSTS
Hi:
If it stuck under the pin, you have two choices. You can try to remove it and gain access to it and repair it that way. However, it may end up broken as a result of opening it up. If you try this, be very careful. If you can't get to it, you will need to replace it.
PS: how did it get under there?
Oct 5, 2008 at 4:01 PM
