Power window (Passenger Front) doesn't work. How can I check if it is the switches or the motor? Which fuse would I check? Thanks
Jul 9, 2009 at 1:23 PM
BMRFIXIT
✓Experienced Mechanic
Both windows at the same fuse
so if driver window working assume fuse is OK
try and use driver side switch does it work on passenger window
I would suspect motor
remove door trim and check
