The other day I arrived home turned off the engine and tried to lock all the doors with the control on the driver's side door. Didn't work. Tried the passenger side door with no luck. Tried the key fob and the horn would beep as if the doors locked but they didn't. Have also found that the power doors won't work either. Replaced the fuse but still have the same problem. Help!
Aug 7, 2010 at 6:05 AM
