2005 Chrysler Town and Country No Spark on Cylinders 1 &amp
70,000 MILES • 6 CYL • FWD • AUTOMATIC
DAVE I.
My engine runs rough and I have a DTC code : 2302.
I changed the coil twice, and replaced the plugs and wires.
I verified that the wire and plugs are good and that I have the correct voltages to the primary side of the coil.
Feb 13, 2010 at 5:14 AM
BMRFIXIT
  • 19,053 POSTS
Are you dealing with a misfiring code P0302?
If so check if have spark at the cylinder
Do a compression test
Check injector and injector pulse
What is missing if any?
Feb 14, 2010 at 10:14 PM
