2005 Chrysler Town and Country Front fan does not work
2005 CHRYSLER TOWN AND COUNTRY
96,000 MILES • 6 CYL • FWD • AUTOMATIC
JOHNSMITH
The fan for the driver's area does not work. I tried to pull the fuse, but could not remove it without forcing it. The fuse appears to be good looking at it. Everything else works from the center counsel, the front fan motor just won't run. What is the technique to pull the fuse? How can I check the switch and motor? How do I replace the switch or motor if I have to?
Mar 1, 2009 at 12:59 PM
ZACKMAN
  • 4,202 POSTS
You have two fans, are they both not running? Or just one not running, if so which one?
Mar 3, 2009 at 4:16 PM
