I recently had a "clunk" in the front end. The garage said I needed new struts & bearing plates which I had installed. Since then the clunk has been eliminated, but when the weather is cold I get a loud noise like metal on metal when going over uneven ground or bumps in cold weather, under 40 degrees. The garage admitted to the noise and after three trips back they still don't know of a solution. Could the struts or bearing plates be defective?
Thank you in Aiken SC
Mar 24, 2008 at 12:42 AM
