2005 Chrysler Town and Country Engine tempurature
98,000 MILES • 6 CYL • FWD • AUTOMATIC
TJENKI7
Temperature gauge goes up and down. The heater inside blows cold air and then after a while it will get hot. I noticed a small amount of water coming out from under the radiator some times when it is parked. Is this a therostat problem?
Nov 29, 2009 at 3:00 AM
  • 110,248 POSTS
Is the coolant full? IF so, I would guess it has something to do with the thermostat. However, low coolant can do the same thing and you mentioned that the rad seems to be lekaing.
Let me know if it is full.
Dec 5, 2009 at 9:17 AM
