2005 Chrysler Town and Country Brakes, calapers, and barein
68,000 MILES • 4 CYL • 2WD • AUTOMATIC
BTAGGART
when you put on the brakes it sounds like metal on metal but the rotors and the brakes are good. sometimes even after releasing the brakes you can still here it and sometimes a few min or longer later you can hear a popping noise and then the noise is gone. almost like the caliper just released.. if you could please help me and let me know what it could be...
Aug 31, 2008 at 5:07 AM
  • 110,244 POSTS
Hi:
Is it possible that the backing plate is bent and rubbing against the rotor? Is the caliper loose?
Oct 6, 2008 at 1:49 PM
