2005 Chrysler Town and Country blower motor control
105,000 MILES • 6 CYL • FWD • AUTOMATIC
HESS666
I have a 2005 t&c and the blower switch quite working. I been looking at other questions and it says something about the resistor being bad, but they all seemed to work on high. Could that be my isue as well? Blower motor still work, just not with the fan controller. And also for the resistor if it only has a front blower can you use a resistor that is for front and rear with no problems? Thanks
Sep 5, 2009 at 3:48 PM
FRAWG
I had the same symptoms with my 05 t&c last year. I replaced the blower motor resistor (about $25 at the dealer parts counter....no one else had it). It was pretty easy to do....pull the glove compartment and remove two screws, basically.
Feb 27, 2021 at 2:17 AM
