2005 Chrysler Town and Country auto door locks
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
WBUSBEE
  • 6 POSTS
can not find fuse.looked in manual and under hood
Jul 29, 2009 at 2:55 AM
DOCFIXIT
  • 18,828 POSTS
Check fuses 14-19 in integrated power module left front engine comp.
Jul 29, 2009 at 3:03 AM
WBUSBEE
  • 6 POSTS
fuses were good.switched around with other fuses and everthing works. thanks for help with fuse location. thanks again
Jul 29, 2009 at 12:09 PM
DOCFIXIT
  • 18,828 POSTS
Your welcome come again
Jul 30, 2009 at 12:55 AM
WBUSBEE
  • 6 POSTS
door locks all working good but now van starter want engage new battery and fully charged.checked fuses and relay and they check ok thanks ps never had trouble before messing with fuses
Jul 30, 2009 at 8:25 AM
DOCFIXIT
  • 18,828 POSTS
Are you useing a meter or test light to check fuses? 40 amp fuse in #19 for door locks did you swap it to #9 40 amp? if yes then that fuse in no good #9 powers solenoid. Check #9 fuse and voltage on yellow/gray wire from starter relay.
Jul 31, 2009 at 1:07 AM
WBUSBEE
  • 6 POSTS
ever thing ok now i hope thanks again
Jul 31, 2009 at 2:12 AM
DOCFIXIT
  • 18,828 POSTS
Glad to help visit again
Jul 31, 2009 at 2:18 AM
