Check fuses 14-19 in integrated power module left front engine comp.
Jul 29, 2009 at 3:03 AM
WBUSBEE
MEMBER
fuses were good.switched around with other fuses and everthing works. thanks for help with fuse location. thanks again
Jul 29, 2009 at 12:09 PM
DOCFIXIT
✓Experienced Mechanic
Your welcome come again
Jul 30, 2009 at 12:55 AM
WBUSBEE
MEMBER
door locks all working good but now van starter want engage new battery and fully charged.checked fuses and relay and they check ok thanks ps never had trouble before messing with fuses
Jul 30, 2009 at 8:25 AM
DOCFIXIT
Are you useing a meter or test light to check fuses? 40 amp fuse in #19 for door locks did you swap it to #9 40 amp? if yes then that fuse in no good #9 powers solenoid. Check #9 fuse and voltage on yellow/gray wire from starter relay.
