2005 Chrysler Town and Country After CV/shaft replacement
60,000 MILES • 6 CYL • FWD • AUTOMATIC
CCORNEAL01
I recently replaced my passenger cv/shaft because of CV joint failure. After having an alignment I have noticed a bad vibration only when I press on the accelerator when I get around 45mph on up. Would this fall back on the alighnment or a faulty shaft maybe?
Apr 17, 2009 at 4:17 PM
CARADIODOC
  • 34,413 POSTS
Alignment issues don't cause vibrations. A worn inner cv joint housing is a common cause, but usually up TO about 35 mph and only when you're on the gas, not coasting. The joint must be disassembled to inspect the housing.
caradiodoc
Apr 18, 2009 at 8:34 PM
