25 amp breaker on the driver
LMONTERO
6 cyl Two Wheel Drive Automatic
where do I locate the 25 amp breaker on the driver side window?
Sep 26, 2009 at 2:12 AM
BMRFIXIT
  • 19,053 POSTS
The window circuit breaker is located in the driver side kick panel. Here is a guide to help you test it.
Here are the fuse panel locations and identifications as well. Check out the window wiring diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Cheers
Sep 27, 2009 at 7:14 AM
