OK under the hood on the left (drivers) side there is a power module and in that is two fuses. They are fuse 19 it is a 40 amp and fuse number 14 a 20 amp. Hope this helps.
Jul 31, 2009 at 2:49 AM
WBUSBEE
MEMBER
thanks
Jul 31, 2009 at 3:13 AM
RACEFAN966
✓Experienced Mechanic
If you need any more help or any walk throughs to do some tests on anything just let me know what you need or what the lock are or aren't doing and I will look them up and help out where I can. Thanks.
