Water leaking inside van
MRJAYRIDE
64,000 miles.
Just out of no where, we developed a leak in our van. It is on the front passenger interior, where the passenger handle attaches to the top of the ceiling. Not sure where this might be leaking from, it is possible that it is coming from the windshield, or from the black rubber strip on the roof of the van which runs down the length of the roof. Is there a way to remove the black rubber strip to see if that is where it is leaking from? Is this a common issue?
Thanks!
Dec 29, 2008 at 12:52 PM
  • 110,248 POSTS
Hi
This is a common issue the windshield is leaking. You will need to have the windshield replaced the stop the leak. If you try to use sealer it will just make a mess.
Dec 30, 2008 at 8:46 AM
KENDRARUSSELL
Mine is leaking in the same spot, but also in the front interior cab lights and around the screws that attach the sun visor to the roof. Clearly not a windshield issue.
May 26, 2018 at 4:56 AM
  • 55,684 POSTS
I am wondering if the sunroof is leaking?
May 26, 2018 at 4:57 AM
