2004 Chrysler Town and Country rear view mirror
2004 CHRYSLER TOWN AND COUNTRY
FUNMAN
Interior problem
2004 Chrysler Town and Country 6 cyl Front Wheel Drive Automatic
Is there a way to keep the auto dimmer feature off at all times unless turned on manually? Right now it comes on at each start
Sep 29, 2008 at 1:53 PM
  • 110,244 POSTS
Hi:
There isn't a switch to turn it off. The only thing you can do is remove the fuse that powers it. However, you will most likely loose the use of other items when you pull it.
Oct 5, 2008 at 3:56 PM
