2004 Chrysler Town and Country O2 Heater circiuits
2004 CHRYSLER TOWN AND COUNTRY
140,000 MILES • 6 CYL • FWD • AUTOMATIC
DBALLARD18
  • 9 POSTS
I have a 2004 Chy T&C, 3.8 liter. I had a bad sensor #1, I replaced both sensors. I still have a couple of codes p032 and P038. The heater circuit high volage on both sensors. From what i have read, this is related to a blown fuse or bad ground wire. I pulled every fuse under the hood and they all look good. I have not been able to locate any other fuse blocks.
1. Is this a fuse issue?
2. Where would the fuse be?
3. Any other toughts would be appreciated
At the same time this occured, the low beam onthe drivers side went out. I changestyhe light bulbs and the front control module to no avail. I do not know if they are related.
Oct 3, 2009 at 2:39 PM
KHLOW2008
  • 41,814 POSTS
Hi dballard18, Thank you for the donation. Here is a description of the problem and diagnostics. Symptom List: P0032 -O2 SENSOR 1/1 HEATER CIRCUIT HIGH, P0038 -O2 SENSOR 1/2 HEATER CIRCUIT HIGH NOTE: All symptoms listed above are diagnosed using the same tests. The title for the tests will be P0032 -O2 SENSOR 1/1 HEATER CIRCUIT HIGH. When Monitored and Set Condition: P0032-O2 SENSOR 1/1 HEATER CIRCUIT HIGH When Monitored: Battery voltage above 10.6 volts, ASD is powered up, and O2 heater is off. Set Condition: Desired state does not equal Actual state. One trip fault. P0038-O2 SENSOR 1/2 HEATER CIRCUIT HIGH When Monitored: Battery voltage above 10.6 volts, ASD is powered up, and O2 heater is off. Set Condition: Desired state does not equal Actual state. One trip fault. POSSIBLE CAUSES O2 SENSOR HEATER OPERATION O2 HEATER ELEMENT O2 HEATER GROUND CIRCUIT OPEN O2 SENSOR O2 HEATER CONTROL SHORTED TO VOLTAGE O2 HEATER CONTROL CIRCUIT OPEN PCM
https://images.2carpros.com/forum/automotive_pictures/192750_HeaterSensor04TownFig26_1.jpg
https://images.2carpros.com/forum/automotive_pictures/192750_HeaterSensor04TownFig27_1.jpg
https://images.2carpros.com/forum/automotive_pictures/192750_HeaterSensor04TownFig28_1.jpg
As to the headlamp, here is a chart for you to understand the possible causes.
https://images.2carpros.com/forum/automotive_pictures/192750_Headlamp04Town_1.jpg
Oct 4, 2009 at 2:07 AM
POLYCHROMEUGANDA
For this particular vehicle there is also a known problem with many ECU firmware versions where neither replacing the O2 sensor nor clearing DTC codes, nor sucessful drive cycles can clear this error once it is set. It is true that the original factory oxygen sensors have a very low resistance when cold (4-8 ohms) while most replacement sensors are higher (10-20 ohms). Installing a currently available "genuine MOPAR" oxygen sensor (OEM Densu) or any other sensor with any chosen cold resistance will not resolve the problem. The code will always return after at least one drive cycle long enough to count followed an idle cycle long enough to cool the engine, followed by a drive cycle. The only resolution is to have a dealer reflash the engine firmware with a corrected version. There is a Chrysler Service Bulletin, however Chrysler is not offering this as a recall item.
With the engine off, disconnect the O2 sensor and check the O2 heater resistance is 20 ohms or less. Reconnect the )2 sensor leads and probe the heater leads with the engine running and verify that the O2 sensor heater is powered, and the ground lead is reasonably grounded. If these basic checks are good, the problem is likely to be the ECU firmware. Some dealerships insist on installing MOPAR 02 sensor(s) for several hundred dollars as a first step. Some dealerships charge $100 to $150 to diagnose and update the ECU firmware. Some dealerships accept the 3rd party diagnosis and the Service Bulletin and perform this brief (10 minute) chore for a fee more likely to encourage your continued patronage.
Jan 4, 2011 at 9:04 AM
POLYCHROMEUGANDA
I should also add that the headlamp failure is unlikely to be related. The circuits do not share a ground as originally configured.
It is concievable, but unlikely that the headlamp failure caused a brief circuit disturbance precisely during the 02 heater functionality test at the beginning of a drive cycle, triggering a false error that was then incorrectly retained by the known ECU firware bug. The more elaborate 02 heater test during the off cycle is described as initiating more than 20 minutes after the engine shuts off, a time when the headlamp is likely to have been on.
Jan 4, 2011 at 9:18 AM
KENBRODY
Is there any chance you know the bulletin number, or have a link, to the O2 sensor / ECU firmware issue? Our Chrysler service center is claiming that there's no such thing as replacing the firmware.
(We have a 2004 T&C, which had the O2 sensor replaced because the code said that was the problem. Our mechanic says the new sensor is fine, and that the dealer needs to update the firmware to handle the new sensors.)
Jan 11, 2013 at 10:08 AM
