2004 Chrysler Town and Country heater/ac control
2004 CHRYSLER TOWN AND COUNTRY
80,000 MILES • 6 CYL • FWD • AUTOMATIC
LARAWAY
I have a 2004 Chrysler van, the heater and ac works ok BUT the knob to direct the air flow does not cause a direction change. It is on the ac vent openings and will not change to def or floor.
It has a back lighted knob and the selector light shows each position when turned but has no effect on the air flow.
The knob for fan speed is the same type with a back light and it works properly.
Thank you
laraway@comcast.net
Jan 14, 2010 at 6:21 PM
BLUELIGHTNIN6
  • 16,542 POSTS
could be caused by loose vacuum hose, need to inspect vacuum connections behind dash.
Jan 15, 2010 at 1:52 PM
