2004 Chrysler Town and Country Heater Blower will not work
2004 CHRYSLER TOWN AND COUNTRY
JIMLEO
Heater problem
2004 Chrysler Town and Country 6 cyl Automatic 107651 miles
How can I get at the front heater switch and blower motor to test each? I have checked the relay and it works.
Jan 15, 2010 at 1:37 PM
BLUELIGHTNIN6
  • 16,542 POSTS
CONTROL PANEL REMOVAL
Disconnect the negative battery cable.
Pull the cup holder out, then remove the small plastic trim piece between the cup holder and the HVAC control panel/radio bezel.
Loosen the 2 lower and 2 upper mounting screws, then remove the HVAC control panel/radio bezel.
Disengage the wiring connectors from behind the HVAC control panel switches.
BLOWER MOTOR REMOVAL
Disconnect and isolate the negative battery cable, then wait 2 minutes before proceeding with the removal. This will effectively disable the air bag system preventing possible personal injury.
Remove the glove box from the instrument panel.
Remove the A/C-heater blower motor cover.
Disconnect the blower motor wiring connector.
Remove the blower motor wiring grommet and feed the wiring through the blower motor housing.
Remove the blower motor mounting screws.
Allow the blower motor assembly to drop downward to clear the instrument panel and remove from vehicle.
Jan 15, 2010 at 1:51 PM
