2004 Chrysler Town and Country
FJLABARBERA
  • 2004 CHRYSLER TOWN AND COUNTRY
  • 6 CYL
  • FWD
  • 64,978 MILES
Check Engine light on. P0440 & P0440 pending code only. Found loose gas cap. Tightened cap then reset code.
Light on again the next day (gas level was about 1/4). Filled tank, cleaned gas cap seal, tighened cap, reset code. Light on when tank level was slightly less than 1/2 full (3/8).
New OEM cap, filled tank, reset code. Light on again at 3/8 tank level. Inspected hoses, purge valve for loose connections and cracks.
Filled tank again. No pending code after @50 miles. After 144 miles (gauge @3/4), P0440 pd set.
Thursday, December 17th, 2009 AT 4:04 PM
  • 109,885 POSTS
A po440 = Evaporative Emission Control System Malfunction. That is a generic code that opens up many possible problems. However, based on your description, I feel you have a small leak in the EVAP. What I recommend is this. Take the car to a shop and have them fog the system. WHat they will do is actually place fog in the EVAP system. If there is a leak, the fog will escape and you then can find the leak. Leaks are very hard to find without this process.
If you have other questions, let me know, and thanks for using 2carpros. Com
Thursday, December 17th, 2009 AT 5:00 PM
